300C Soft Brake Pedal
Old Sep 4, 2006 | 12:45 PM
Mark's Avatar
Default 300C Soft Brake Pedal
I have a new 2006 300C Heritage with <1000 miles. The brake pedal will go to the floor with continued pressure. The car stops okay, but the brake pedal does need some travel before the brakes respond. Dealer says its "normal" and would not do my request to bleed the system. I bled the system with a pressure bleeder and didn't really see any air. The pedal does not change its firmness with pumping, so I don't think air intrusion is the problem. I think the master cylinder maybe be bypassing. I am more of an aggressive driver and like responsive brakes. This is my first Chrysler so I am not sure if the "feel" is normal. Any comments? Specifically on the 300C (which is supposed to have "big" brakes)?
Old Mar 8, 2008 | 07:00 PM
karayj's Avatar
Default RE: 300C Soft Brake Pedal
My car does the same and canot get an anser on this board. I repalce the master clylinder and reaplce the ABS pump then bleed the brakes and it was fine. 1 Month later its back and tell the dealer it is not normal !!!
Old Dec 9, 2014 | 10:12 PM
John Rivera's Avatar
2008 v6 300 Chrysler LX brake pedal will go to floor if foot pushed; after having complete brake work front and rear with new master cylinder.. Is this Normal.
Old Dec 10, 2014 | 09:13 AM
With the engine running, the power brake system will allow the pedal to go to the floor if you press hard enough and long enough.
Try turning the engine off and apply the brakes several times to deplete the power brake system. The pedal then should be firm.
monsterdub
May 5, 2024 11:10 AM
kkc
Mar 31, 2015 02:26 PM
ke6oqc
Dec 20, 2012 11:44 AM
Hawwk11
Nov 24, 2009 07:34 PM
May 10, 2006 05:36 PM
