Can I separate 2.7L engine from auto trany?
Old Nov 1, 2007 | 10:07 PM
andbudzi's Avatar
Default Can I separate 2.7L engine from auto trany?
I have 01 Sebring with 2.7L engine, Is it possible to remove engine without taking transmition out?
Old Nov 2, 2007 | 10:05 AM
96lxisebring's Avatar
Default RE: Can I separate 2.7L engine from auto trany?
i dont see why not you can do it w/ pretty much any other fwd ive seen
Old Nov 2, 2007 | 02:20 PM
moe's Avatar
moe
hey bud this is right from our web site at chrysler.you can work around this ,you don't have to follow to the letter but i think it will help.moe
[ol][*]Release fuel pressure(Refer to 14 - FUEL SYSTEM/FUEL DELIVERY - STANDARD PROCEDURE).[*]Disconnect negative battery cable.[*]Drain cooling system (Refer to 7 - COOLING/ENGINE - STANDARD PROCEDURE).[*]Discharge A/C system using a suitable refrigerant recovery machine.[*]Remove throttle body air inlet hose and air cleaner housing assembly.[*]Raise vehicle on hoist.[*]Remove both front wheels.[*]Remove left and right splash shields.[*]Remove fasteners attaching lower front fascia to crossmember.[*]Remove fasteners attaching lower air shield to crossmember.[*]Remove front bumper fascia.[*]Lower vehicle.[*]Remove upper radiator crossmember.[*]Disconnect upper and lower radiator hoses at radiator.[*]Using a blade or suitable hose cutter, cut transaxle oil cooler lines off flush with fittings. Plug lines and fittings to prevent debris from entering transaxle or cooler circuit. A service splice kit will be installed upon reassembly.[*]Disconnect A/C lines at condenser. Remove cooling module (fan, radiator, A/C condenser).[*]Disconnect transmission electrical harness connectors (C104 & C105) (Refer to 8 - ELECTRICAL/CONNECTOR/GROUND LOCATIONS - DESCRIPTION).[*]Disconnect transmission shift cable.[*]Disconnect engine electrical harness from PCM and bulkhead connectors.[*]Remove fasteners attaching ABS brake module to lower radiator crossmember. Support module with a suitable retaining strap.[*]Disconnect brake line from retaining clips that attach to lower radiator crossmember.[*]Raise vehicle.[*]Remove both axle shafts (Refer to 3 - DIFFERENTIAL & DRIVELINE/HALF SHAFT - REMOVAL).[*]Remove front engine mount through bolt. Remove front engine mount from lower radiator crossmember.[*]Remove lower radiator crossmember.[*]Remove accessory drive belts (Refer to 7 - COOLING/ACCESSORY DRIVE/DRIVE BELTS - REMOVAL).[*]Remove power steering pump and bracket as an assembly. Do not[/b] disconnect power steering lines from pump. Reposition pump and support with suitable retaining strap.[*]Disconnect heater return hose from pipe connection at right front frame rail area.[*]Disconnect A/C compressor electrical connector.[*]Remove A/C compressor mounting bolts. Reposition A/C compressor and support with suitable retaining strap. Generator can be removed with engine assembly.[*]Remove structural collar (Refer to 9 - ENGINE/ENGINE BLOCK/STRUCTURAL COVER - REMOVAL).[*]Remove the exhaust cross-under pipe (Refer to 11 - EXHAUST SYSTEM/CROSS-OVER PIPE - REMOVAL).[*]Remove rear engine mount and transaxle bracket.[*]Drain engine oil.[*]Remove transaxle torque converter housing cover.[*]Mark flex plate to torque converter position. Remove torque converter bolts.[*]Lower vehicle.[*]Disconnect positive cable from battery and PDC.[*]Disconnect ground cable from left side transaxle mount bracket.[*]Disconnect throttle and speed control cables.[*]Disconnect coolant pressure bottle coolant hose from engine coolant outlet connector.[*]Disconnect heater hose from engine coolant outlet connector.[*]Disconnect ground strap at right shock tower.[*]Disconnect fuel line.[*]Disconnect brake booster and vapor purge vacuum hoses.[*]Disconnect all ground straps attaching to engine.[*]Position vehicle height to allow engine dolly 6135 and cradle 6710 with posts 6848 to be installed under vehicle.[*]Loosen cradle engine mounts to allow movement for positioning onto engine locating holes on the engine block, compressor mount bracket and oil pan rail. Lower vehicle and position cradle until the engine is resting on posts (ENGINE REMOVAL CRADLE). Tighten post mounts to cradle frame to prevent movement when removing or installing engine/transaxle assembly. Secure engine/transaxle assembly to dolly/cradle with safety straps.[*]Lower vehicle so weight of the engine and transmission ONLY is on the cradle.[*]Remove right and left side engine mount bolts.[*]Slowly raise vehicle in short length spans. Inspect at each interval for potential engine or transaxle contact to vehicle components. Move the cradle/dolly fixture as necessary to allow for removal clearance[/ol]
Old Nov 3, 2007 | 11:07 AM
andbudzi's Avatar
^ chrysler is saying to remove trany with engine, i am wondering if anyone had took it out without removing trany? Trany removal probobly is required when you droping an engine, but i want take it out from the top...remove radiator and suport, move it forward and up.
Old Feb 10, 2023 | 12:18 AM
This&That's Avatar
Did you end up able to remove it from the top?
aricker74
Jan 8, 2012 08:19 AM
buddy7
Oct 2, 2011 08:46 AM
sonician
Oct 28, 2010 04:35 AM
dwsracing
14
Jan 29, 2010 11:50 PM
01sebring
Mar 17, 2008 05:14 PM
