Compressor switching on and off
Old Jun 11, 2018 | 10:06 AM
Luuk's Avatar
Default Compressor switching on and off
My Ac compressor will turn off randomly sometimes and blow warm air for a while but I figured out that if I pop the hood and tap on the compressor fuse it’ll kick on. I have replaced the fuse, checked wiring, tightened fuse holder, changed relay. Anyone know what could be causing this??
Old Jun 11, 2018 | 10:14 PM
Low refrigerant?
Old Jun 11, 2018 | 10:16 PM
Luuk's Avatar
Low refrigerant?
could be but why would it kick on once I tap the fuse?
Old Jun 11, 2018 | 10:27 PM
its best if you provide all that info to start with oh the compressor will kick it when the fuse is wiggled. then u have a loose connection.
First logical thing would be low freon high cycle times the low freon will keep the pressures out of range.
Old Aug 22, 2019 | 03:09 PM
boatmoter's Avatar
low freon or you have a bad hi or low pressure sensor
Old Aug 22, 2019 | 04:43 PM
jtcooks's Avatar
Low freon might solve the issue
Old Aug 22, 2019 | 05:31 PM
REBEL59's Avatar
LOL ! Responding to a 1+ year old thread to someone that didn't give a model or year of vehicle in question . AND then didn't bother to read his only response that it would work when he tapped (moved) the a/c fuse. It has a problem in the fuse panel solder joints , as he said he tightened the prongs that hold the fuse.
BUT ....Yes it COULD also be a little low on refrigerant as a secondary issue.
And on researching the member's past postings... it's a 2012 300 s model
Old Aug 28, 2019 | 11:06 AM
boatmoter's Avatar
bypass the fuse with a jumper lead then see if it still cuts in & out
doitmyself
May 8, 2018 08:16 PM
va300m
Aug 7, 2013 01:25 PM
andyb2000
Jul 19, 2011 08:38 AM
dhhbomb
Aug 29, 2009 07:51 PM
jake763
Oct 18, 2008 05:54 PM
