help 04 Pacifica fan relay location?
Old Mar 21, 2009 | 08:56 PM
rojo's Avatar
Default help 04 Pacifica fan relay location?
check engine light on, over heated once, code says check relay and wiring. I did not locate relay in fuse/relay box next to battery. Am i missing it or is it located somewhere else?
Old Mar 21, 2009 | 10:21 PM
dusty-schaffner's Avatar
before spending any money make sure the fan actually runs, open the hood and stand outside the car while its running, watch the temperature and dont let it overheat too much but make sure the fan actually kicks on
Old Mar 22, 2009 | 09:22 AM
rojo's Avatar
fans (dual) do not come on. I ran the temp up pretty high on the gage, and they never came on. Fans may be bad, but thought I should start with relay and fuses.
Old Apr 7, 2009 | 08:04 PM
rojo's Avatar
Default Anyone??
Where is it???? I have checked in the fuse/relay box, under the box, and on the frame rail left front, and still cant find the cooling fan relay.
???? Anyone have a clue where this thing is?
Old Apr 7, 2009 | 10:25 PM
REMOVAL
Open hood.
Disconnect and isolate the battery negative cable.
Partiacially remove the front fascia to gain access to the radiator fan relay (Refer to 23 - BODY/EXTERIOR/GRILLE - REMOVAL).
Disconnect the relay electrical connector (RADIATOR FAN RELAY).
Remove the rivet attaching the relay to the front bumper beam (RADIATOR FAN RELAY).
Remove the relay.
its behind the front bumper
dwtcst
Jan 16, 2011 07:16 PM
northwind
Jan 14, 2011 02:07 PM
rojo
Mar 22, 2009 09:25 AM
dphickster
Feb 3, 2009 01:38 AM
defektivrobot
Apr 22, 2008 12:47 PM
