Help. 2000 Chrysler circus 2.4
Old 06-12-2017, 01:55 PM
tr5211's Avatar
Default no one has a solution!!!! 2000 Chrysler circus 2.4
chrysler cirrus 2000 2.4 100,000 miles
when I try to start the car it just cranks-- when I try again it starts- I put a spark plug tester between the coil and the plug no spark the first time but I do the 2nd time --I replaced the crank sensor and cam sensor and it's the same where do I go from here is there a relay in the fuse box?
Old 06-15-2017, 10:56 PM
what are the codes in the computer?
Old 06-16-2017, 09:35 AM
tr5211's Avatar
There was 2 codes crank sensor and small evap leak it starts if I keep cranking with the spark tester on between the coil and plug no spark unless I keep cranking the engine thanks for responding
Old 06-20-2017, 01:09 AM
replace the crank sensor
Old 06-21-2017, 08:40 PM
tr5211's Avatar
Old 06-23-2017, 01:03 AM
ok then what is the code for the crank sensor just because the word crank sensor is in it does not mean that the issue. Need code number.
Old 06-23-2017, 03:40 PM
tr5211's Avatar
Default 2000 cirrus
The two codes are po340 and po391 I replaced both an stats hard like I said I Put a spark tester between the coil and plug and no spark unless I keep cranking then if I let it sit for a half hour same problem it's not fuel because I sprayed ethanol and same problem once the spark shows it starts
Old 06-24-2017, 12:26 AM
p0391 is not a valid code Look at the crank sensor wires are they full of oil?
Old 06-25-2017, 07:04 AM
tr5211's Avatar
Default Cirrus
no the wires are dry
s.wilson1978@yahoo.com
07-12-2011 02:19 PM
daryls377
11
06-12-2010 09:02 AM
alfman123
08-14-2009 10:19 PM
elbocoupe
11-18-2005 08:30 PM
Quick Reply: Help. 2000 Chrysler circus 2.4
