neon runs for 20 minutes then cuts out.
Old Apr 24, 2010 | 05:13 AM
baz58's Avatar
Default neon runs for 20 minutes then cuts out.
hi, can anyone please help, i have a 1999 neon 2L 16v se.
it will start from cold with no problems and gets up to normal water temp, the radiator fan kicks in with no problem and every thing seems ok but then it cuts out after 15-20 minutes and will not start for hours usually overnight, has any one had the same problems.
Old Apr 24, 2010 | 04:40 PM
Possibly a clogged fuel filter. Had similar problems years ago and that's what it turned out to be.
Old Apr 24, 2010 | 05:41 PM
baz58's Avatar
is it possible that the crank shaft position sensor is faulty !
Old Apr 25, 2010 | 12:23 PM
Unlikely that it will run at all with the crankshaft position sensor being bad. Have you checked for codes?
Old Apr 26, 2010 | 02:58 AM
baz58's Avatar
Have checked for codes they are P1684 and P0320 what does this mean ?
NickF
Mar 2, 2014 11:01 AM
jonjamesbuckley
Sep 22, 2012 08:50 AM
cajunsprt
9
Jan 25, 2008 01:06 PM
DJ_Playing
Apr 22, 2006 03:58 PM
