PT CRUISER CUT OFF
Old Sep 22, 2007 | 12:52 PM
  #31
Gold Cruiser's Avatar
Default RE: PT CRUISER CUT OFF
I'm a retired Crane Operator. Just glad to be of some help to you. Thank you and good luck, Tommy.
Old Oct 12, 2007 | 05:58 PM
  #32
moe's Avatar
moe
if im not mistaken you can cycle your key three times(leave it turned on)and watch the speedo cluster and write down the "P" codes set by your check engine light.let me know what codes you have and i'll let you know whats wrong.the pt cruiser is one of the cars that spits out codes on cluster.let me know moe!
Old Oct 19, 2007 | 03:35 PM
  #33
moe's Avatar
moe
hey gold,you really walked that guy thru his problem.cool bro.nice to see people helping people.like they say "pass it forward" moe
Old Oct 20, 2007 | 12:30 AM
  #34
Hey Moe, I see you are doing the same! That is great. I have always felt that if you help others, or at least try to help others, something good will happen in your life. Many good things have happened for me. Nicecommunicating with you. Aloha, Tommy.
Old Nov 8, 2007 | 09:43 AM
  #35
moe's Avatar
moe
hey tommy how do i find out when someone has responded to a posting ?any short cuts ? glad we can help others.someday we will need help about something were not sure of. talk later my friend!moe
Old Nov 15, 2007 | 10:19 PM
  #36
Hi Moe, sorry, I took so long to respond. I have been busy. Just could not find the time to get to these forums. Usually when I submit a post, I'll put a check in the box below that says: Notify me via e-mail when someone replies. That's how I know if someone has responded to my post. Hope that helps, Tommy.
Old Jun 25, 2012 | 08:01 PM
  #37
Tashia Dudley's Avatar
Unhappy OMG It keeps cutting off while I drive
Ok guys I have had so many different sensor, relay, battery, spark plugs & wires changed, I have had the idle adjusted, but this pt crusier is cutting off on me while I drive. Does anyone have a under the hood fuse designation to tell me what my fuses are for. Or any suggestions to help. PLEASE
Old Jun 25, 2012 | 10:41 PM
  #38
your owners manual will have the location of the fuses and FYI u can not adj the idle dont let any one fool u with that line
Old Jun 26, 2012 | 05:21 PM
  #39
There is a tamper proof that you need a star bit with a hole in it to adjust it and that was done right infront of me and it brought my idle from 1/8 rpm to almost 1 rpm in park drastic change and now it doesn't cut off when I go to stop or driving slow cause gasing and breaking at the same time isn't fun. I bought the car used so I don't have a user's manual. I have tried to pull diagrams online but don't see any that gives me the fuse designation. It however still cuts off while I am driving, not at a stop but driving like 65 miles and hour.
Old Jun 27, 2012 | 12:31 AM
  #40
U are not suppose to move that screw it is set at a certain step All u did was adj the air flow going into the car the computer controls the fuel so what u though u did the computer simply adj the fuel mix back to what it wants.
U need to have a good scanner hooked up to it to see what the codes are.
Ryan Przytula
Aug 14, 2014 07:23 PM
joker2cv
May 31, 2012 10:11 AM
tcossuto
Dec 27, 2007 08:20 PM
Feb 3, 2006 06:34 AM
Feb 1, 2006 01:57 AM
