Rad cap
Old Sep 11, 2012 | 08:59 PM
Craigsebring's Avatar
Default Rad cap
Hello,
I would like to drain, flush and refill my radiator but I'm a little confused with the Sebring. In my previous vehicles the rad cap was on the actual radiator and the overflow tub was aside and had its own cap. With my '06 Sebring touring all I see is the cap on the overflow tub at the side of the vehicle. My question is, is the overflow cap the point of entry for me to refill the rad? Is this referred to as a closed system?
Such an amateur question but I've not been able to find anything out online.
Thanks in advance,
Craig
Old Sep 11, 2012 | 09:30 PM
remove the lower radiator hose
Old Sep 11, 2012 | 10:29 PM
Yes, you fill at the cap on the overflow reservoir. If yours is a 2.7L engine, DO NOT, repeat, DO NOT attempt to bleed the system using the bleed screw on the water outlet manifold at the top of the engine. Attempting to do so will, in all likelihood cause the insert into which the bleed screw fits to spin in the plastic where it is mounted resulting in a leak and ruining the part.
Fill until the reservoir is full and re-fill if necessary after driving the car through a few warm-up and cool-down cycles.
Old Sep 12, 2012 | 10:15 AM
Thank you both.
Okay, so I will drain the rad, cycle through the rad flush fluid, drain, then refill. My only question left is, if I'm bypassing the petcock and simply disconnecting the lower rad hose (method I have not done before) to drain, is the hose simply connected by a ring clamp? I just don't want to damage the hose upon disconnection / reconnection.
Cheers,
Craig
Old Sep 12, 2012 | 11:37 AM
it prob has a factory hose clamp its spring loaded look at the ones on top and U will see what they look like
Old Sep 12, 2012 | 11:52 AM
Cheers, thanks again
lexi
Apr 10, 2011 06:38 AM
guetch5
Jan 11, 2011 12:04 PM
plen123
Aug 10, 2008 04:37 PM
seawind3000
May 16, 2008 11:44 PM
davidandkeiley
9
Jun 4, 2007 07:07 PM
