Stratus 1999 ABS light ON
Old Apr 7, 2019 | 11:54 AM
Gerard Osaica's Avatar
Default Stratus 1999 ABS light ON
Hi everyone
In my Stratus 1999 the ABS lamp is always on, and the tester sees "no trouble codes". Can you help me somehow?
greetings to Gerard
Old Apr 7, 2019 | 01:25 PM
REBEL59's Avatar
Originally Posted by Gerard Osaica
Hi everyone
greetings to Gerard
An generic(less costly) OBD11 scanner will NOT pick up ABS or SRS codes. Need one that also interfaces with the BCM computer. BUT you can start by checking for a bad ABS fuse or relay in the fuse panel.....
Old Apr 7, 2019 | 01:41 PM
Thanks for a quick answer. I checked the fuses and relays.
I guess there is nothing else to go to the Chrysler car service
Can I check something myself?
gerard
Old Apr 7, 2019 | 03:37 PM
REBEL59's Avatar
gerard
Once code(s) can be retrieved, they are pretty specific to the cause of the light coming on and staying lit, usually a wheel speed sensor that has gone bad. IF you use an Independent shop for your service work, they should have a scanner capable of doing that. ABS and SRS(air bags) have been around for a number of years now...to keep current a good Independent shop should be able to handle it at much less cost than a Dealer.
Poad
Oct 18, 2016 03:17 PM
BillT
39
May 8, 2016 01:43 PM
dandy
Oct 29, 2012 08:36 PM
Gasman
Jan 15, 2011 09:07 AM
gadgetman
Aug 6, 2010 06:17 AM
