where did my spark go
Old Mar 4, 2017 | 12:43 AM
isaacray's Avatar
Default where did my spark go
i got 83 chrysler lebaron 2.6 liter. i have no spark. testwd and replaced all thw way down the line. replaced plugs, plug wires, cap and rotor, ignition control module, distributor, coil and condensor. still no spark. dont know where to go from here. any advice would be highly appreciated
Old Mar 4, 2017 | 09:25 PM
Check all the grounds for corrosion and continuity. All the way back to the battery.
Old Mar 6, 2017 | 12:59 AM
isaacray's Avatar
i checked all the ground straps as well as the the power wires from the ignition switch. Just in case. there are two wires coming off distributor a blue one and i blk w white tracer. which one goes on (+) and which one goes on (-). Then there are two coming from a wire loom. A dark blue with red tracer and a black with yellow tracer. which one goes to (+) and which one goes to (-). the wire diagram i was going off of had a few wires of different colors. not to clear. thank you
Old Mar 6, 2017 | 09:39 AM
I do not know which of those wires goes where as I do not have access to a wiring diagram for your car. I can tell you, that generally speaking, it is automotive practice that power comes through red wires, ground through black wires. The tracers are to distinguish individual sources, like switches and fuses for the power and ground.
There is a chance that a wiring diagram for your car could be found at 12volt.com but that site is more focused toward stereos and things like that.
Make sure that the distributor you are trying to install really is for your car. The discrepancy in the colors of the wiring could be a clue that it is not the right part.
WillQRose
Oct 18, 2018 07:18 PM
austin
Cirrus & Breeze
Sep 16, 2012 09:09 PM
brock
Nov 18, 2006 08:37 PM
kato11141
Jan 31, 2006 11:42 PM
Dec 5, 2004 02:55 PM
