K-Cars Talk about the infamous K-Cars within.
90 New Yorker headlight problems
Old Jun 18, 2013 | 09:13 PM
AngryDad's Avatar
Default 90 New Yorker headlight problems
Good evening folks,
I'm new to this forum so please bear with me. I recently purchased a 1990 New Yorker Fifth Ave for the bargain price of $950. Seemed like a good purchase on the test drive, but after I got it home I discovered a problem. The low beams only work occasionally. High beams work fine. Last week I replaced the turn signal switch but no difference. Low beams run on fuses, so them working occasionally can't be the problem. There is a relay under the hood labeled "lamps". Don't know if that could be the problem. Today I got in the car to work on it and the battery is completely dead. Started fine when I bought the car but it won't even begin to take a charge now. My thought is I've got a bad ground somewhere. Anyone have any ideas?
Old Jun 19, 2013 | 05:51 PM
AngryDad's Avatar
My mistake. There is no relay labeled "lamps", just a 50A fuse.
Old Jul 22, 2013 | 08:11 AM
BarnetteMichael's Avatar
From: 747 S Ridgewood Ave # 205, Daytona Beach, FL 32114
I think you should tell this problem about the car to that person from whom you have buy it.
Old Sep 12, 2015 | 01:43 PM
N.Numchuck's Avatar
could be a lot of things. Try cleaning ground connections to lights. Then check all connections. One thing that goes bad you didn't mention is the light switch itself. The one you pull out to turn lights on. They do go bad from use.
If you a vom and can use it or just simple test light probe and know how to use it comes in handy.
mr_ed_55
Aug 16, 2015 09:14 AM
k5kzv
Jan 21, 2013 10:26 AM
tedhodges
Nov 3, 2011 10:05 PM
gregb
Jul 9, 2011 10:36 PM
rone15
Dec 21, 2008 01:24 PM
