2.7l v6 engine cranks but wont run
Old Aug 31, 2022 | 12:51 PM
dftrampage's Avatar
Default 2.7l v6 engine cranks but wont run
my 2006 chrysler sebring convertible touring 2.7L v6 will crank over and stumble to run but turns off immediately . i have fuel pressure tested,check fuses,checked relays,changed out crankshaft and camshaft sensors....still nothing. at one point the engine stayed on for 10 min then shut off and didnt start again. i had a mechanic with a huge scanner come by the house and ran test...he said the engine is fine and that the problem lies in the electrical.....has anyone heard of this happening ?
roland
Old Sep 1, 2022 | 06:09 PM
CanadianSebringJR's Avatar
it could be as simple as a short where wiring rubbed through somewhere, or a bad as an ECM replacement. id try running ground continuity tests on the main plugs on the harness first with a multimeter.
i can only ask one other question, do the the lights on the dash go dim and bright while its running? if so its definently a ground connection gone bad.
Vision2099
Jan 23, 2017 10:10 PM
mikeinaus
Apr 22, 2012 08:32 AM
04_sebring
Nov 21, 2011 10:48 PM
homer2105
Oct 12, 2011 09:48 PM
musicfreak2195
Jun 9, 2010 01:15 PM
