2006 Pacifica 3.5. Grinding noise after shutdown
Old May 13, 2018 | 09:56 AM
Doworkscotty26's Avatar
Default 2006 Pacifica 3.5. Grinding noise after shutdown
Hear like a grinding noise when I turn my Pacifica off... Don't think it's the starter cause it starts fine. Noise only lasts 1 to 3 seconds. What could it be? Car has oil in it. Any help would be great..
Old May 13, 2018 | 11:34 AM
FIREM's Avatar
Belt noise? Check belts first. Loos belt alternator may want to keep going when engine is shut off. Not sure about Pacifica but some cars turn on A/C and engine fans at key off. Could cause unusual noise, maybe ??
Check the bolts between the engine flex plate (flywheel) and torque converter. Have seen them cause noise at shut down.
Old May 14, 2018 | 04:56 PM
Default Thanks
Thank you. Sounds like it is on top of the engine. Had a auto zone guy listen at shut down. Going to mechanics Wednesday and hopefully it isn't expensive or get worse.
Old May 19, 2018 | 07:20 AM
Default Fixed
was the alternator that was bad. Thank you.
frankyb23
Jul 10, 2011 07:49 PM
il_capo_dei_cattivi
Dec 21, 2010 11:21 PM
blackice
Aug 5, 2010 01:50 PM
kristiruman
Jun 25, 2010 02:11 PM
EricB
Sep 15, 2009 06:59 AM
