Brake Problem
Old Apr 19, 2015 | 12:17 PM
DRDitty's Avatar
Default Brake Problem
Have a 2001, 300M 3.5L 70000 miles. While driving, brakes were normal then suddenly half of the brake system failed. The brake pedal had to be pushed almost to the floor to achieve braking. No warning lights of any kind and no sign of fluid leaks, reservoir was full. Pumping does not achieve pedal pressure. Replaced master cylinder and bled IAW instillation instructions and Haynes repair manual. Problem still persists. The way the car is driven probably never activates the ABS. I'm thinking one of the solenoid valves in the valve block assembly has failed??? Anyone seen this before or have any ideas. Thanks
Old Apr 19, 2015 | 03:40 PM
Welcome to the forum. You have posted your question in the new members forum where people introduce themselves. You might have a better chance of getting a meaningful reply by posting your question up in the forum for Chrysler 300 owners, further down the page. good luck.
Old Apr 21, 2015 | 02:31 PM
Shep's Avatar
You may have to bleed the ABS system in conjunction with a Bi-directional scanner. Some cars, like Buick's, require a scan tool to actuate the solenoid to bleed the system. Not sure if 300M's have those but just a thought.
Old Apr 22, 2015 | 09:16 PM
DRDitty's Avatar
Thanks guys, found the problem! The new master cylinder that I bought was defective. Thanks for the input.
monsterdub
May 5, 2024 11:10 AM
4everrunning
Jun 4, 2019 11:30 AM
andrew143
Jun 2, 2009 06:44 AM
Josho
Oct 23, 2008 10:42 PM
