Other Any other Chrysler within.
Sebring 2004 Compressor power issue
Old Apr 27, 2019 | 09:08 AM
sebringguy's Avatar
Angry Sebring 2004 Compressor power issue
Hello all. First post here. I realize this is a general issue. I have an '04 Sebring 2.4 Sedan that I cannot get the AC to run. I ran a circuit tester from battery to compressor plugin interface and got a negative light. I found the compressor relay in the fuse box and removed the relay, put a paper clip in to get the compressor clutch to engage/disengage. I turned on the engine and A/C full blast and when engaging the paper clip in the relay interface was able to get cold air to blow and my thermometer reflected the temp dropping rapidly. So I figured bad relay, right? Went to parts store and bought relay. Put in fuse box, turned on AC, still warm air and compressor not engaged. Went to another store just on chance relay was not good and got same results. I verified the compressor is OK and got cold air once manually engaging with the paper clip. But I stick in new relays and STILL doesn't work? Why could this be?
marcpilot1
May 29, 2017 09:31 AM
jds
Aug 14, 2012 08:24 AM
andyb2000
Jul 19, 2011 08:38 AM
dhhbomb
Aug 29, 2009 07:51 PM
jake763
Oct 18, 2008 05:54 PM
