faulty wheel cylinder?
Old Aug 23, 2018 | 03:00 PM
megapossum's Avatar
Default faulty wheel cylinder?
While rebuilding the drum brakes on a 92 Lebaron I was replacing the wheel cylinder on one side and as I was attaching the brake line when I noticed that the nut on the brake line wasn't getting as tight as it should. Looking closely under a light I saw as I was turning the nut that the threaded part of the wheel cylinder was turning right along with the nut. This the first time I've encountered this situation. I wondered first if it would leak and thought it probably would. Since I'd ordered it rather than buying it locally, it would take several days to return it and get a replacement. Also the shipping costs will be rule this out.
I wondered if I could undo the brake line and remove the threaded nipple from the brake cylinder. If so and I applied the Red Loctite on the threaded area that is in the brake cylinder, would this secure the nipple in the cylinder so I could attach the brake line normally? Has anyone had this problem and if so how did they solve it?
2004SebringSedan2.4L
May 10, 2019 09:55 PM
ReluctantMech
Feb 11, 2018 07:17 AM
mark34050
Mar 23, 2014 12:00 AM
arveetek
Jan 31, 2011 10:15 AM
BJF1280
Jan 23, 2011 09:27 AM
