HELP! 98 Cirrus abs issue
Old Dec 27, 2013 | 07:29 PM
drewblueeye3's Avatar
Default HELP! 98 Cirrus abs issue
I have a 1998 chrysler cirrus with the v6. i have an issue with the brakes. everytime i start up the car whether it is cold or hot, and no matter how many times i drive it through out the day it always does this for the first 2 or 3 times braking. i presson the brakes normally and the ABS kicks in, the brakes pulsate then the ABS light comes on. then the ABS light stays on for as long as i drive the car. then i shut the car off, turn it back on the ABS light is off until i brake for the first couple times and the brakes pulsate again.
you can even hear the abs kick in. the noise the ABS makes just like you were sliding on ice and pressed the brakes. and it does it EVERYTIME. after the first 2 or 3 times it wont do it anymore until i turn the car off.
any ideas?
Old Dec 27, 2013 | 09:50 PM
U get an abs scanner and see what the abs codes are then go from there
jimmy154
Dec 14, 2019 09:45 PM
busboy4
May 2, 2012 11:15 PM
alexyoung59
Oct 20, 2011 07:37 PM
quattj
Sep 24, 2011 08:34 PM
Gasman
Jan 24, 2011 12:23 PM
