Rear defrost and heat mirrors problem
Old 12-09-2013, 03:03 PM
2010vert's Avatar
Default Rear defrost and heat mirrors problem
2010 sebring convertible . The rear defroster and heated mirrors work intermittently - the light comes on always when pushed and goes off in 10 minutes or so . I looked at fuse under hood and it looks fine . The two tabs on window are secure . Is there a relay component that may be bad ? Where ? What else could be reason ? Thanks
Old 12-10-2013, 09:14 AM
Check your owners manual. That's the way it's supposed to work.
Old 12-10-2013, 10:28 AM
2010vert's Avatar
I may not have been clear in my description . By intermittently working I meant it works sometimes fine then sometimes it does not work at all - I realize it turns off after 10 minutes of heating - the problem is it does not heat mirrors or window sometimes - I found what may be problem - I pushed the top up button to tighten top and it allowed rear defrost to heat . I understand that if top down it deactivates rear defrost operation - maybe a top up or top down sensor is not registering correctly - or it may be a coincidence .
arihan
12-05-2023 10:15 PM
ss4993
10-29-2019 08:22 PM
JasonCNY
08-16-2011 07:00 AM
prsolar2001
12-05-2009 04:29 PM
RobW
11-14-2008 10:54 PM
Quick Reply: Rear defrost and heat mirrors problem
