Sponsored by:
Sponsored by:
2000 t&c 3.8
Old 06-01-2012, 04:53 PM
dwsracing's Avatar
Default 2000 t&c 3.8
My van always fired right up on first hit of the key. The fuel pump went bad, replaced pump and gas filter. Now it takes 3 or 4 times to start when cold. Seems ok when hot. Did a fuel pressure test and seems great but not to familiar with fuel injection, yet lol. Any ideas or things I am missing on this issue, thanks.
Old 06-01-2012, 09:24 PM
put the fuel pressure on the port and turn it over watch to see where it stops should be 55 then walk away for a few hours come back then see if the pressure has dropped down below 40 or something like that
Old 06-02-2012, 08:21 AM
dwsracing's Avatar
I did check, it was at 55. But it dropped fast to 19.
Old 06-02-2012, 01:28 PM
the fuel pump either has a bad check valve or something like that
Old 06-02-2012, 02:28 PM
dwsracing's Avatar
Well after thinking, it most likely is fuel pump related, that is what was changed.
Old 06-02-2012, 09:13 PM
maybe the parts u are getting does not have the check valve in it I have no idea
Old 06-03-2012, 06:18 PM
dwsracing's Avatar
I think this is the one I got, will double check Buy Airtex Fuel Pump Module Assembly E7094M at Advance Auto Parts Hoping they will replace it for me. My son works there so with alittle luck.
Old 06-10-2012, 09:44 AM
dwsracing's Avatar
Update, It was a bad pump. Replaced and starts as it should now. Thanks for all the help, this form Rocks !!!
Old 06-10-2012, 11:34 AM
welcome
Old 06-10-2012, 07:01 PM
TNtech's Avatar
If your son works at a parts store, see if they can get discount Mopar parts from the dealer. I know it works the same for us >>> the other way around.
DRFUZZ
01-06-2010 10:19 AM
ladyas
12-13-2009 06:09 PM
d3aglewhor3
05-05-2009 12:58 AM
chryslervan
03-21-2009 10:07 PM
chryslervan
03-16-2009 07:02 PM
Quick Reply: 2000 t&c 3.8
