Sponsored by:
Sponsored by:
Abs/brake light
Old 02-16-2013, 03:41 PM
pestilance's Avatar
Default Abs/brake light
2.8crd grand voyager,my abs light is on and also traction controll disabled
and now and then the brake light on dash illuminates.
also noticed if i bring the car to a stop quick ,car not moving but speedo then falls down from 10 mph to 0
whats the easiest way to check the abs sensors to find out which 1 is dodgy?
brake light coming on ?
Old 02-17-2013, 03:05 AM
tfb's Avatar
tfb
tfb is offline
A scan tool will tell you which has failed, or you can test the resistance with a multimeter. Though a multimeter will only tell you if the sensor has failed and wont be able to check that the sensor is correctly located and the rings are OK.
However, if 3 sensors read the same resistance and one reads different then you can be fairly sure that one is the culprit.
Regards
Richard
Old 02-17-2013, 03:04 PM
Scotsman4th's Avatar
2 years running I got my ABS light to go out by washing around all the sensors using a pressure washer.
This MOT, it didnt work. Neither did cleaning the rings with a screwdriver and wire brush.
The garage ended up replacing the 2 front sensors, think they had test equipment good enough to tell them the sensors were u/s.
jimmy154
12-14-2019 09:45 PM
4everrunning
06-04-2019 11:30 AM
Vincenthrd
07-29-2009 02:09 PM
Vincenthrd
07-28-2009 02:44 PM
Evapa
12-23-2008 12:54 AM
Quick Reply: Abs/brake light
