Sponsored by:
Sponsored by:
Transmission light on after battery change
Old 02-05-2014, 11:39 AM
richjones19772000's Avatar
Default Transmission light on after battery change
Hi guys, just fitted a new battery in my 2002 2.5CRD voyager, took it out for a quick spin and the engine management light came on and the car also went into limp mode, stop for a few mins and the light was still on but it was driving normal. Had the bonnet open whilst I was changing the battery and it was raining pretty heavy any chance a bit of water could be the culprit ?
Cheers
Old 02-05-2014, 02:24 PM
tfb's Avatar
tfb
tfb is offline
try doing the key dance to see what fault codes are logged.
Regards
Richard
Old 02-05-2014, 04:04 PM
Regards
Richard
is that's the on/off on/off on/off method?
Old 02-06-2014, 01:51 AM
tfb's Avatar
tfb
tfb is offline
yep, thats it
Old 02-06-2014, 04:46 AM
yep, thats it
Hi i did the key dance. The code that was shown was P010.0?
Old 02-06-2014, 09:05 AM
tfb's Avatar
tfb
tfb is offline
P0100 is the Mass Air Flow sensor.
Time to get a multi meter out and check some of the voltages.
It will report a fault if the reference voltage is below 4.8 or 5.2V (but most likely other items would report faults if that was the case)
It will report a fault if the sensor voltage is less than 0.2V or above 4.5V
It will also report a fault if the sensor voltage does not match what it expects given the current engine load, this can be the hardest to diagnose as it may not be the MAF, eg an air leak in the intake system can cause this.
I'll ulpoad the MAF connector details later
Regards
Richard
Old 02-06-2014, 10:20 AM
Default Maf
Regards
Richard
Thanks for that Richard, would this also cause the car to into limp mode? for a brief spell yesterday it had minimal power and then it came back, been fine since?
Old 02-07-2014, 01:51 AM
tfb's Avatar
tfb
tfb is offline
MAF connector is here
https://skydrive.live.com/redir?resi...nt=file%2c.pdf
and yes, it would cause it to go into limp mode
Regards
Richard
darkcild101
54
10-02-2014 05:13 PM
Edengweiss
06-19-2014 05:34 PM
littlestoney406
02-15-2011 11:05 AM
pdh
04-21-2009 04:16 PM
jmm
08-31-2006 08:05 PM
Quick Reply: Transmission light on after battery change
