Sponsored by:
Sponsored by:
U110c message- no fuel level bus message
Old 05-03-2008, 01:15 PM
dphickster's Avatar
Default U110c message- no fuel level bus message
I've gone a long ways back on the thread and can't find anything on this. While driving, my RPMs sometimes drop, then come back. Error light came on and this is the code my reader came up with. My reader didn't have this error code in it's memory, had to look it up on line. Does anyone have any idea what I might need to look at to fix this?
Old 05-03-2008, 02:18 PM
dphickster's Avatar
Default RE: U110c message- no fuel level bus message
should mention: 2005 T&C with 3.3 and 51k miles
Old 05-04-2008, 12:33 PM
Symptom:
U110C-NO FUEL LEVEL BUS MESSAGE
When Monitored and Set Condition:
When Monitored: Ignition on.
Set Condition: No fuel level BUS messages received by the PCM for 20 seconds.
POSSIBLE CAUSES
DTC RESET
COMMUNICATE WITH BCM
PCI BUS CIRCUIT OPEN FROM PCM TO BCM
BCM
TEST ACTION APPLICABILITY
1 NOTE: If a fuel level circuit or performance DTC is set along with P1681,
diagnose the circuit/performance DTC before continuing.
Turn the ignition on.
With the DRBIIIt, erase DTCs.
Start the engine on and off several times. Leave the engine running for at least 20
second each time.
With the DRBIIIt, read DTCs.
Does the DTC reset?
All
Yes ! Go To 2
No ! Refer to the INTERMITTENT CONDITION symptom in the
Driveability category.
Perform POWERTRAIN VERIFICATION TEST VER - 1 - NGC.
2 Ignition on, engine not running.
With the DRBIIIt, attempt to communicate with the BCM.
Can communication be established with the BCM?
All
Yes ! Go To 3
No ! Refer to the Communication Category and perform the appropriate
symptom related to no communication with BCM.
3 Turn the ignition on.
Using the DRBIIIt, read the Fuel Level parameter in the PCM.
Does the DRBIIIt display a fuel level value?
All
Yes ! Replace and program the Powertrain Control Module in accordance
with the Service Information.
No ! Go To 4
287
DRIVEABILITY - NGC
4 Turn the ignition off.
Disconnect the PCM harness connectors.
Disconnect the BCM harness connector.
CAUTION: DO NOT PROBE THE PCM HARNESS CONNECTORS. PROBING
THE PCM HARNESS CONNECTORS WILL DAMAGE THE PCM TERMINALS
RESULTING IN POOR TERMINAL TO PIN CONNECTION. INSTALL
MILLER SPECIAL TOOL #8815 TO PERFORM DIAGNOSIS.
Measure the resistance of the PCI Bus circuit from the BCM harness connector to the
appropriate terminal of special tool #8815.
Is the resistance below 5.0 ohms?
All
Yes ! Replace BCM in accordance with the Service Information.
No ! Repair the PCI Bus circuit between the PCM and the BCM for an
open.
Old 05-04-2008, 05:50 PM
dphickster's Avatar
dude, a little more
english!!
Old 05-05-2008, 10:13 AM
if u want it done correctly U should have a dealer take a look at it from the diog it looks like U will need a DRB inorder to show what voltage is at the computers and such.
Old 05-05-2008, 09:00 PM
dphickster's Avatar
Thank you, but what is a DRB? The van is now parked at the airport while the wife is away on business. She reported that the light did not go out on the way to the airport. I've got 10 days grace to try to find other owners with similar problems before I will have it back to take to the dealer.
webnet
09-02-2019 02:26 PM
Dan B1
03-11-2012 12:10 PM
Dan B1
03-10-2012 03:45 AM
jgraham
05-04-2011 11:03 AM
feenicks
10-19-2008 06:32 PM
Quick Reply: U110c message- no fuel level bus message
