Transmission failure after engine swap
Old 11-30-2014, 02:12 AM
Mohsen Dehghan's Avatar
Unhappy Transmission failure after engine swap
I bought a 2000 chrysler cirrus Lxi 2.5 L two months ago. The engine was not running correctly and I decided to swap it with another one.
After replacement, now engine is working very good but there is another problem here. Transmission does not work correctly. When I shift it in Drive mode, It doesn't start running. But when i slam the gas pedal (I mean when the rpm goes higher than 3000) it starts running very very slowly.
It also makes a weird noise (like boom boom) while running.
I hooked up a scanner and got the codes which are listed bellow:
P0700
P0732
P0734
P1782
I also found that it just runs when the transmission fluid is fully filled (more than the maximum level),(about 2 gallons) and I see the fluid leakage underneath the car while it runs.
Old 11-30-2014, 10:05 AM
ahhhh you get to take the engine or trans back out and see what you did wrong. Sorry to say but its not a natural failure it was man made.
miles2go
10-11-2013 06:55 AM
allsho80
06-08-2009 01:35 PM
dusty-schaffner
02-13-2009 09:30 PM
andbudzi
02-20-2008 04:07 PM
96concorde
09-10-2007 08:15 PM
Quick Reply: Transmission failure after engine swap
