neon runs for 20 minutes then cuts out.
Old 04-24-2010, 05:13 AM
baz58's Avatar
Default neon runs for 20 minutes then cuts out.
hi, can anyone please help, i have a 1999 neon 2L 16v se.
it will start from cold with no problems and gets up to normal water temp, the radiator fan kicks in with no problem and every thing seems ok but then it cuts out after 15-20 minutes and will not start for hours usually overnight, has any one had the same problems.
Old 04-24-2010, 04:40 PM
Possibly a clogged fuel filter. Had similar problems years ago and that's what it turned out to be.
Old 04-24-2010, 05:41 PM
baz58's Avatar
is it possible that the crank shaft position sensor is faulty !
Old 04-25-2010, 12:23 PM
Unlikely that it will run at all with the crankshaft position sensor being bad. Have you checked for codes?
Old 04-26-2010, 02:58 AM
baz58's Avatar
Have checked for codes they are P1684 and P0320 what does this mean ?
NickF
03-02-2014 11:01 AM
jonjamesbuckley
09-22-2012 08:50 AM
cajunsprt
9
01-25-2008 01:06 PM
DJ_Playing
04-22-2006 03:58 PM
Quick Reply: neon runs for 20 minutes then cuts out.
