94 Chrysler concorde cranks but won't start and headlights flash for 3 minutes
Old Dec 7, 2018 | 05:41 AM
Jholliday420's Avatar
Default 94 Chrysler concorde cranks but won't start and headlights flash for 3 minutes
Car cranks but won't start and the headlights flash for 3 minutes. Anyone habe any idea what could cause this. I've replaced the ignition starter switch check the spark fuel pressure and cam n crank sensors all seem to be fine and still won't start. Help please
Old Dec 7, 2018 | 08:44 AM
REBEL59's Avatar
Wow, that's getting to be an "oldie"! Does this car have a factory alarm/anti theft? The flashing headlights seems to indicate that. And in your workings with it may have activated it. Try a complete battery disconnect for a few hours (some call a hard reset) and then try it....Good Luck!
Old Dec 7, 2018 | 09:43 PM
Battery has been disconnected for 2 days and it still does it. Thanks for the idea tho I greatly appreciate it.
Old Jan 2, 2019 | 12:18 PM
RShoaf's Avatar
I would agree that it sounds like an alarm issue, but it might be an aftermarket.
If a factory alarm it can be shut off by turning either door to unlock with the key.
If that doesn't work, look under the dash for a box with aftermarket wiring. It will have a inline fuse holder on the wiring. Remove that fuse.
Now look at the wires. Two of the wires coming from the black box will be spliced into a wire coming from the factory ignition switch ( lower part of the steering column.)
Disconect the aftermarket wires from the factory wires and splice the factory wires back together. Your car will now start.
iluvdiznee
Apr 8, 2021 10:51 AM
Joi
Jun 24, 2018 09:25 AM
ccdlpd
Jun 3, 2014 04:22 PM
size2020
Sep 18, 2010 11:24 AM
acmectec2001
Jan 1, 2007 06:51 AM
