LHS brake problem
Old Feb 17, 2012 | 08:22 PM
keithm's Avatar
Default LHS brake problem
Pedal on this 99 model, was very stiff and braking seemed a little weak, if you push the pedal hard and fast it would free up and have nice feel for a while, then it would go back to the same thing. about a week ago light pressure slowed the car normally but if more pressure was required it took 2 feet to stop the car. It sounds like the primary circuit in the mastercylinder is bad. I'm thinking replacing the master cylinder is the next step since I have no codes stored, does this sound correct?
Keith
Old Feb 17, 2012 | 11:10 PM
U wont have any codes for a system that is mechanical and no sensors
Plus u would need a scanner that can get into the abs system not the engine computer.
Old Feb 18, 2012 | 10:15 PM
keithm's Avatar
Default abs
it has abs that wouls require a few sensors
Old Feb 19, 2012 | 05:28 AM
the wheel speed sensors are only used to see if one or more wheel is moving faster then they others then the abs system applies brake pressure to slow the faster slows down there are no other sensors in the system for brake pressure like what u are experiencing. Most people go through there whole cars life with out ever having experienced using the ABS system so it is vary rarely used.
Yes u would need a scanner that would work only for the ABS system that system is not a federal mandated setup that everyone needs to be able to look at for for every day use.
Old Feb 19, 2012 | 06:44 AM
keithm's Avatar
Default abs
i understand how the system works, just wondering is the issue im experiencing sounds like a master cylinder
Old Feb 19, 2012 | 08:30 AM
keithm's Avatar
Default power brake booster
just wanted to make sure its not the power brake booster
Old Feb 19, 2012 | 08:48 AM
your power brake booster is not electrical as well it vacuum controlled
Old Feb 19, 2012 | 10:31 PM
keithm's Avatar
is there any reason I should assume that the hard pedal with almost no braking would be the power booster?
Old Feb 19, 2012 | 11:17 PM
Possible if u replace the booster replace the master cyl while u are there
monsterdub
May 5, 2024 11:10 AM
4everrunning
Jun 4, 2019 11:30 AM
andrew143
Jun 2, 2009 06:44 AM
Josho
Oct 23, 2008 10:42 PM
