1997 Sebring
Old Feb 25, 2014 | 03:14 PM
carbineone's Avatar
Default 1997 Sebring
Hi, new here and my Son has a 97 Sebring with a V6 engine..
Though it was 5 degrees last night it would not start today.
It will run though. The main problem he is having is when it is running, it idles great. But you press the foot feed quickly and it sounds like it is running on maybe one cylinder. No power whatsoever.. Just almost completely dies but does not. Let off and it idles perfectly again. If we drive it and work the throttle up very slowly it will eventually take and go like a rocket till you let off, slow down and it all starts over again..Any thought appreciated.. Seems this would be a problem that should be well known.
Old Feb 25, 2014 | 06:11 PM
Try cleaning the throttle body.
Old Feb 25, 2014 | 06:30 PM
carbineone's Avatar
We will try that tomorrow and let you know. Should we remove it and use carb or brake cleaner? Whats the general method? Thanks
Old Feb 26, 2014 | 09:31 AM
Get some throttle body cleaner. Yes, you'll need to open things up to get in there.
Read the instructions on the can, don't scrape anything, let the stuff work. A toothbrush is about as aggressive as you'll want to get.
Old Feb 28, 2014 | 09:34 AM
carbineone's Avatar
Well that was not it.
Old Mar 4, 2014 | 08:47 PM
carbineone's Avatar
Thanks Decotter. You must be the only other member here. This place stinks.. Farewell
RogueInLA
Mar 31, 2014 08:54 AM
ernie
Sep 20, 2007 01:22 PM
baseballchris05
May 7, 2007 09:52 AM
ChryslerNamedTrixie
Dec 15, 2005 04:46 PM
carman4433
Aug 8, 2005 08:00 PM
