2000 jxi 2.5 l
Old Oct 5, 2013 | 10:36 AM
Lightman's Avatar
Default 2000 jxi 2.5 l
Hello All,
I am having two problems as a result of a bad head gasket. I have replace the head gaskets, water pump, timing belt, timing belt tensioner, spark plugs, wires, distributor cap & rotor. #1 piston (bent rod) and a valve lifter. All this because I change the coolant. Just goes to show, that you shouldn't do preventive maintenance.
1st, the engine now lacks power. and according to my vacuum gauge, I have late ignition timing. I have pulled the front of the engine down and verified cam & crank alignments. I have checked and solved a small vacuum leak at the EGR tube at the upper intake manifold. Still lacks power and doesn't like to shift until RPM is above 4K. I did the cam & crank position sensor reset by placing in low gear and getting engine RPM above 4K, 3 times without braking. I'm looking for other possibilities.
2nd, not quite as serious but I used the radiator draincock to drain the coolant and now it leaks. I've attempted to remove to replace but cannot get it to release from the radiator, and ideas?
Beware_of_Dog
May 26, 2010 06:18 AM
owoody
Mar 16, 2009 10:26 PM
craigspeedy
Feb 28, 2009 07:38 PM
mybring2000
May 20, 2008 12:00 PM
VJoseph
Feb 17, 2008 08:24 PM
