98 jxi no crank
Old Feb 18, 2012 | 09:50 PM
hoss's Avatar
hi there yes removed battery from car and took it to parts store autozone
Old Feb 19, 2012 | 05:24 AM
what what were the readings when they tested it?
Old Feb 19, 2012 | 09:22 AM
hoss's Avatar
i think it was 14.6 and 10.9 i know he assured me that it was good the battery is 1 1/2 years old
Old Feb 19, 2012 | 04:27 PM
and the CCA? if they load tested it that will show u what the CCA was at the time which I am suspecting it is low like in the 300 range.
U can have a battery 12volts and 0 cca and the car will not turn over.
Old Feb 19, 2012 | 05:56 PM
  #15
hoss's Avatar
should i have it tested again for cca's i going to try the battery from ford diesel which i know has big cca's to see will it start again many thanks for all your help so far
Old Feb 19, 2012 | 06:40 PM
  #16
hoss's Avatar
next test pulled wifes expedition next to it disconnected battery cables on jxi connected jumper cables to pod ang neg on jxi still nothing not sure if this is to be expected just letting you know tried ir both with expo turned off and running still nothing
Old Feb 19, 2012 | 11:19 PM
  #17
replace the battery how many days have u wasted trying to look past the obvious
Old Feb 20, 2012 | 09:12 AM
  #18
I'm not so sure the battery is the problem if it won't start after jumping from the truck.
Maybe it's time to get busy with that volt-ohmmeter and check for continuity and signal starting at the starter and working backwards toward the key.
That .16 Amp you got doesn't necessarily mean anything. When you disconnect the battery there's a little surge when it's first reconnected.
PowerAuthority
Oct 13, 2009 05:49 AM
sassycc
Jun 30, 2009 02:51 PM
sumncguy
May 19, 2007 01:28 PM
BigBlocksnHardrock
Apr 7, 2007 12:19 PM
Tripp1117
Cirrus & Breeze
Jan 28, 2007 01:37 PM
