Hard starting on cold mornings
Old Dec 22, 2014 | 06:27 PM
purplepuller's Avatar
Default Hard starting on cold mornings
04 Sebring 2.4 Cold morning(28 deg) just open door and reach in to start car and it starts, rumbles a little bit and stalls. Have to get in a push accelerator while cranking to get running. then runs and idles fine? Did the cycling of fuel pump the other morning and still didn't start right up.
Old Dec 22, 2014 | 06:44 PM
Any codes? I wonder if the ambient air temp sensor is acting up.
Old Dec 22, 2014 | 07:31 PM
No codes. Wandering if the car had a coolant temperature sensor or something like that. Old 89 Lebaron had CTS and it went bad and car ran super bad until replaced.
Old Dec 22, 2014 | 08:16 PM
Even if I don't have the outside air temp readout, the ambient air temp sensor will still effect the running of engine?
Old Dec 23, 2014 | 03:12 PM
The computer reads the ambient air temp to decide how rich the mixture needs to be, kind of like the old days when you had a choke to help start the car on cold mornings. If the temp gauge on the dash is working, then the coolant temperature sensor is ok. The gauge gets its input from that sensor.
Old Jan 8, 2015 | 12:42 PM
1 above this morning and car wouldn't start, turned over ok but no fire. Ordered Factory OEM ambient temp. sensor last Monday so hope to get it today and replace it this weekend. Not suppose to be as cold tom. morning. Had Diesel plugged in and drove it to work.
Old Jan 15, 2015 | 06:43 PM
Finally got the new Ambient Temp. Sensor. Installed it this evening. Very hard to get to. Took 6 clips off bottom of front facsia to get arm up behind grill to get to it. Hopefully it takes care of start up on cold mornings. Also got new PCV valve and installed it too.
Old Feb 3, 2015 | 06:40 PM
Well 9 above this morning and no start. So stopped at Advance auto today after work and got coil(Borg Warner) Plug wires (Autolite) and Plugs (Champion copper). Car still won't start this evening so changed coil with flashlight. Car started and put in garage to change plugs and wires. Plugs were shot 59,800 miles. Seems to run fine.
nativefirefighter
Feb 16, 2010 08:22 AM
follett108
Nov 24, 2007 09:24 AM
backyardbill
Cirrus & Breeze
Oct 1, 2007 10:38 AM
cheechster
Feb 7, 2007 07:31 PM
rfaricy
16
Jan 9, 2007 03:00 AM
