Help!! water leak no source
Old Oct 28, 2007 | 11:16 AM
pghtomo's Avatar
Default Help!! water leak no source
Hello,
I recently purchased a 2003 sebring lx coupe w/ moonroof. I noticed floor was damp on drivers side early on and assumed it was moonroof leak or someone left something open. After a week of dry weather I noticed it was still damp. Early one morning car was covered in dew and drivers side floor was wet again. Then it rained next day and floor was soaked. I have searched high and low inside cannot determine where this water is coming in at. Moonroof is dry during storms, door doesn't have any signs of leaks. carpet is wet twards the front left side of drivers foot area which leads me to believe it is coming in door jam area or under dash/vent area????? All gaskets appear to be in great shape? Does anyone know of this problem? I have a coworker w/ a 2001 convertable with same problem. I think his is more related to having a rag top though. Please help me here....I open to any suggestions. Thanks
Old Oct 28, 2007 | 11:21 AM
master tech's Avatar
Default RE: Help!! water leak no source
The drains could be plugged or pinched, is the sunroof factory or aftermarket?
Old Oct 28, 2007 | 11:33 AM
pghtomo's Avatar
it is a factory sunroof.
Old Oct 28, 2007 | 11:37 AM
pghtomo's Avatar
Drains? Where do they drain from and where canI find access to them? Does the water normally drain through the floor area? I can't understand the thought behind this. If the drain is pinched or plugged up, then water builds up on my drivers side floor? Is it building up somewhere else then overflowing into driving compartment?
Old Oct 29, 2007 | 10:28 PM
You should have two drain going down the A-Pillars and two for the rear, C-Pillars.
Old Nov 24, 2007 | 09:00 PM
just don's Avatar
With my 2004 Sebring Convertible passenger side floor leak it was related to the air conditioning condensate drain. Water can cling to the underside of the discharge tube concealed by the rubber boot/drain tube. The water accumulates inside the boot and flows back into the car through the firewall. Apparently whatever gasket is at the firewall fails over time. I solved it by removing the boot and attaching a 5/8" i.d. hose to the discharge pipe and ran it below the frame.
Just Don
clambert
Apr 21, 2015 10:14 AM
Only306
Nov 17, 2011 07:47 AM
captain catfish
Oct 2, 2010 04:32 PM
jim@letjimdoit.com
Aug 3, 2008 09:10 PM
myrtinfl
Jun 22, 2007 07:44 PM
