Newbie Questions
Old Mar 16, 2007 | 07:05 PM
69roadrunner's Avatar
Default Newbie Questions
I just purchased a 2000 Sebring JXi Convertible w/ the 2.5L... I love it! But, I want to make it better...
Simple stuff at first, like headlights...
Are there any options other than the OEM style? Like solid chrome, or better yet, projectors?
And gauges? White faced perhaps?
There is all sorts of aftermarket goodies for the coupes and sedans, how much, if any, will interchange?
Oh, and to clear something up, is the 2.5L DOHC or SOHC? It appears to be DOHC and looks like a small 3.5, but I've been told it's SOHC... I'd like to know...
Also, what are the factory performance specs for that engine and year?
Thanks. guys!
Old Mar 16, 2007 | 11:01 PM
Default RE: Newbie Questions
2.5L ENGINE
DESCRIPTION The 2.5 Liter (152 cu. in.) 60° V-6 engine is a single overhead camshaft (per bank) with four valves per cylinder design
2.5L V-6 Engine The engine does not have provisions for a free wheeling valve train. The firing order is 1 - 2 - 3 - 4 - 5 - 6. The cylinders are numbered from the front of the engine to the rear. The front cylinder bank is numbered 2, 4, and 6. The rear cylinder bank is numbered 1, 3, and 5.dont have a performance spec that can be looked up online
Old Mar 17, 2007 | 04:12 AM
Umm, ok, if it has a single cam on each side, and it is of a V design, and has two sides, doesn't that make it a DOHC?
I have a 95 Intrepid with the 3.5L... It also has a single cam over each bank. It is referred to as DOHC...
Just curious.
Also, what do you mean by "the engine does not have provisions for a free wheeling valve train?"
Old Mar 17, 2007 | 11:13 AM
silver01v6's Avatar
no, for it to be a DOHC motor you would need to have two cams in EACH head.
Old Mar 17, 2007 | 02:46 PM
3.5 has never been a DOHC. A non free wheeling engine is where if something happened aka a timing belt broke or something along that line it would bend valves and cause all kinda damage. A free wheeling engine will just spin becasue there is enough clearence between the valves and pistons that it wont hurt anything if something breaks. The older 3.5 is free wheeling
Old Mar 20, 2007 | 06:30 PM
could swore the window sticker on that 3.5 said DOHC - oh well... no matter...
Will those 3.5s fit into the Sebrings? We've got one that's been warmed up a little to around 240 - 250 horses... it would turn this sebring into a nice sleeper...
Old Mar 20, 2007 | 10:23 PM
no comment I am not into making changes on factory systems
badabing67
Oct 29, 2007 07:54 PM
BOBE
Jun 27, 2007 05:12 PM
sumncguy
May 9, 2007 09:36 PM
riverrat
Jun 5, 2005 01:55 PM
Mar 2, 2005 03:29 PM
