Oil leak at sensor
Old Dec 16, 2017 | 07:56 PM
Ericbo101's Avatar
Default Oil leak at sensor
I have an engine oil leak at a sensor position (back of the engine, just above the right drive axle close by the transmission (see the picture). Hope you could help me confirm this makes sense (I watched see the oil dripping so pretty sure) and understand what this sensor is ... I will be happy to buy the sensor and any oring going with it to fix the leak
Thank you all !
Old Dec 17, 2017 | 07:23 AM
FIREM's Avatar
Oil pressure light switch leaking. Best to buy OEM as aftermarket ones tend to cause issues with light flickering at idle.
Old Dec 17, 2017 | 11:04 AM
flaokie's Avatar
That is a leaking oil pressure switch.
When you replace the switch, be sure to completely clean all the oil off of the connector and it’s contacts.
On a 2.L V6 a leaking oil pressure switch is not uncommon.
The location of the switch subjects it to very high heat. (I moved the switch on my 2.7L to up in the engine compartment.)
A flickering dash oil light is usually caused because hot oil pressure at idle in a 2.7L is right around 5psi – the set point of the pressure switch.
Old Dec 17, 2017 | 11:00 PM
Ericbo101's Avatar
Thank you both !!
Will go order and change it (and clean carefully)
Much appreciated Eric
kythri
Aug 19, 2017 10:53 AM
milesy_boy
11
Nov 19, 2009 05:34 PM
garr5859
Aug 21, 2007 11:51 PM
jason1
Nov 9, 2006 05:28 PM
Cat
Mar 1, 2006 08:25 PM
