P0882
Old Nov 10, 2022 | 04:10 AM
Cames's Avatar
Default P0882
I have a 2010 sebring 2.7 bought it at auction went to get it found out the transmission is in limp mode with p0882 code we have changed computer, tipm, and transmission still stays in second gear all the time. The last time I messed with it the starter stopped working with the key when I try to start it it just clicks once and won't turn over I can jump the starter and it will turn over and start just not with the key not sure if that has anything to do with the transmission problem been messing with it for about 6 months would like to get it fixed and gone thanks for any help.
Old Nov 10, 2022 | 09:18 AM
Sounds like a dead battery. Will help the starting problem, might even help the transmission problem. The transmission is controlled by a computer. Computers don't like weak sources of electricity (low voltage).
Old Nov 10, 2022 | 10:19 AM
Cames's Avatar
New battery and the starter turns fine if I jump it
Old Nov 11, 2022 | 11:13 AM
Check the battery leads for corrosion and conductivity.
Nd48463
9
Jan 20, 2018 11:15 AM
george3405
Aug 9, 2017 02:51 PM
keheid2003
Feb 28, 2014 11:19 PM
jesse
Oct 18, 2011 12:19 PM
04_pacifica_4u
May 17, 2009 09:51 AM
