Power windows 10 sebring
Old May 16, 2016 | 05:59 PM
slimmanx's Avatar
Default Power windows 10 sebring
HI
Just recently my passenger power window stopped working. Well the driver switch stopped working and the passenger's switch will only work the window down. Not sure if its the motor or the switch. Any advice on what is wrong or how to troubleshoot?
Old May 17, 2016 | 09:02 AM
ChryslerCares's Avatar
Originally Posted by slimmanx
HI
I recommend contacting your local FCA dealer for further assistance. Let me know if you need help making an appointment - Kevin T, Social Connect Team
Old May 17, 2016 | 10:48 AM
Look for a broken wire in the bundle of wires leading into the door. It happens from flexing as the door opens and closes. Start with the driver's side. That gets the most use.
Old May 17, 2016 | 12:15 PM
slimmanx's Avatar
From the car to door correct?
Old May 18, 2016 | 09:50 AM
Right.
Where it bends when the door opens.
Old May 20, 2016 | 01:23 PM
slimmanx's Avatar
How much power should be coming from the switch to the motor? I get roughly 14 and -14 from each switch (up and down positions).
Old May 20, 2016 | 04:07 PM
14 what? Volts, amps? "Power" is measured in watts, which is volts times amps.
What exactly are you measuring and where exactly are you measuring it? Are you measuring volts at the motor or at the switch? It makes a big difference.
Old May 20, 2016 | 05:04 PM
slimmanx's Avatar
At the connector for the motor. I have the multi meter set to volts.
Old May 21, 2016 | 10:51 PM
If you are getting full battery voltage right at the motor but the motor is not responding then wouldn't it be logical that there is something wrong with the motor?
Princessmobile
Other
Jul 19, 2017 11:09 PM
Frosty68
May 6, 2013 08:44 PM
Richard T
Mar 9, 2012 12:49 PM
cstingray
Sep 21, 2009 09:10 PM
Sofargone
Jun 25, 2005 10:28 PM
