Removing Connector From Brake Light Switch (2010 Sebring)
Old Nov 11, 2016 | 08:55 PM
mhozian's Avatar
Default Removing Connector From Brake Light Switch (2010 Sebring)
Anyone know how to remove this type of connector from the brake light switch? I've tried just about everything at this point. Sheer force alone doesn't work. There has to be some type of release mechanism I'm not seeing that allows it to disconnect. I've already tried messing with the various green tabs without any luck.
Attached Thumbnails Removing Connector From Brake Light Switch (2010 Sebring)-img_20161111_1433060_rewind.jpg
Old Nov 12, 2016 | 02:45 AM
AnthemBassMan's Avatar
From: T-County, Ohio. Good ol' farm country! Or at least what's left of it...
Do you have a pic of the other side? I think there's a lock that you have to slide back before trying to disconnect the wiring harness. It should be on the backside of the black piece. Then squeeze a small tab while pulling up on the grey part of the harness.
L8R,
Matt
Old Nov 12, 2016 | 12:04 PM
mhozian's Avatar
There's nothing on the back side of the black part of the switch unfortunately. Nor is there any discernable tab anywhere that can be squeezed. Other than the green tabs on the front, which I've already messed with extensively. Whatever the trick is I imagine has to do with them. I'm just not sure exactly what it requires.
4everrunning
Jun 4, 2019 11:30 AM
BURPLE
Mar 20, 2014 07:32 AM
CruiserNick
Aug 15, 2012 03:15 PM
bds0688
Jul 26, 2010 03:28 PM
GLC
Oct 5, 2007 01:11 PM
