Replacing the rear passenger window motor -2005 Sebring Convertible
Old May 22, 2015 | 03:28 PM
tsprinkle's Avatar
Default Replacing the rear passenger window motor -2005 Sebring Convertible
The rear passenger window on my convertible is not working. I cannot hear any noise from the motor, so am assuming/hoping it is the only thing bad. (The cost of the regulator and motor is prohibitive at this time) So I bought the motor. I have watched many videos on how to remove the regulator, but none go the extra step to remove the motor. Is the motor removal pretty straight forward after the regulator is out?
Does anyone have a manual diagram and instructions on how to replace the motor?
Thanks in advance for any responses.
Old May 22, 2015 | 03:56 PM
I've never done a motor swap, but the shop manual warns that you need to "secure the sector gear to the mounting plate with a C-clamp" when removing the motor. It does not provide a drawing. Apparently there are some spring loaded forces that you need to be aware of.
Come back and tell us how it went.
Before you pull it apart, make sure it's not a wiring or switch problem rather than the motor itself. Use a multimeter to make sure you're getting juice back there when the switch is thrown.
57toplessatlast
Oct 11, 2013 08:26 AM
motley1987
May 25, 2013 08:54 PM
cwilliams35
Jul 28, 2011 10:53 AM
windex42
Dec 12, 2009 09:34 AM
hildenja
Aug 3, 2007 07:07 AM
