Seatbelt Chime
Old Jan 24, 2020 | 09:09 PM
cjb108's Avatar
Default Seatbelt Chime
Seatbelt chime
I have a 2004 2.7L Chrysler Sebring convertible. Once I put it in gear, the seatbelt chime sounds a set of five chimes, 12 times in a row. That's a total of 60 chimes EVERY time I put it in gear and start moving! The driver's-side seatbelt chime is disabled (by turning on the ignition, buckling and unbuckling the seatbelt three times in 10 seconds and turning the ignition off) and the passenger seat is empty when it does this. I've disconnected both driver- and passenger-side seatbelt sensors to no avail. Can someone please tell me how I can fix this!? Cuz it's starting to drive me a little nuts! Any info anyone can give me will be greatly appreciated.I have a 2004 2.7L Chrysler Sebring convertible. Once I put it in gear, the seatbelt chime sounds a set of five chimes, 12 times in a row. That's a total of 60 chimes EVERY time I put it in gear and start moving! The driver's-side seatbelt chime is disabled (by turning on the ignition, buckling and unbuckling the seatbelt three times in 10 seconds and turning the ignition off) and the passenger seat is empty when it does this. I've disconnected both driver- and passenger-side seatbelt sensors to no avail. Can someone please tell me how I can fix this!? Cuz it's starting to drive me a little nuts! Any info anyone can give me will be greatly appreciated.
Old Jan 25, 2020 | 09:25 AM
You haven't stated whether you are actually buckling the seatbelt around you to drive the car. If you are driving the car without the belt properly buckled around you, you are taking your life in your hands, especially in a convertible.
Old Jan 25, 2020 | 08:33 PM
cjb108's Avatar
I assumed that it'd be a given.....my bad. Everyone in the has their seat-belt on, but the chime still sounds 60 TIMES every time I start it up and get rolling.
Old Jan 26, 2020 | 09:16 AM
"I've disconnected both driver- and passenger-side seatbelt sensors to no avail."
Try replacing the sensors (Probably will require replacing the belts.) Disconnecting the sensors is probably telling the computer that the belts are unbuckled.
Old Jan 26, 2020 | 02:45 PM
cjb108's Avatar
Default sensors
Can you tell me if the seat-belt sensors are simple switches or something more complex? Can I check them with an ohmmeter?
Old Jan 26, 2020 | 08:04 PM
The way I interpret the wiring diagram, it's a switch, with a light green/red wire leading to it and a black wire leading from it. Of course, it's connected to a "controller" which is basically a "black box" on the wiring diagram, which means it's a computer-controlled device whose logic is not spelled out. So there could be something wrong with that component. Good luck.
Old Jan 26, 2020 | 09:32 PM
cjb108's Avatar
thank you for your help. I let you know if and when I fix it.
Old Apr 4, 2020 | 04:56 PM
cjb108's Avatar
Hey I fixed the chime problem. I pulled the chime module from the BCM circuit board. I still have the flashing seat-belt light, but it flashes in SILENCE! Thank you for your help.
cjb108
Jan 24, 2020 09:05 PM
Emtronics
Jan 29, 2015 04:05 AM
Emtronics
Mar 17, 2012 09:51 PM
judlicht
Jun 24, 2008 04:39 PM
Skookill
Dec 28, 2007 04:06 PM
