300c drive train vibration
Old May 21, 2005 | 10:53 AM
dalvan1's Avatar
Default 300c drive train vibration
my 2005 300c has had a drive train vibration since new. I had the tires rebalanced with no change. It occurs only at 1750 rpm in overdrive. Has anyone else had this problem??
Old May 24, 2005 | 05:35 PM
fatcat's Avatar
Default RE: 300c drive train vibration
no sorry icant help. i dont have that problem or i have actuallly never heard of it.
ace?
Old May 26, 2005 | 12:53 AM
ace's Avatar
ace
ahh shux thanks for the boost of confidense
anyway what gear do you think its in i know they have a 3rd to 4th gear shudder with the nag1 trans
its got to do with water in the trans they do a complete flush and it should fix it if it is.
other than that i am going to start to inquire on this one.
Old Jun 17, 2005 | 12:37 AM
gam300c's Avatar
HAY, I HAVE AN 05 300C IT TO HAD A VIBRATION, MINE WAS DO TO THE CROSS MEMBER UNDER THE CAR THAT WAS RESTING ON THE EXHUST SYSTEM. I HAD THE DEALERSHIP BEND IT DOWN AND IT WENT AWAY. THE 300C SETS LOWER THAN I THOUGHT AND THE BAR GOT BENT WITHOUT ME KNOWING IT, HAVE SOMEONE OR YOURSELF LOOK AT IT.
LATER
Old Jun 23, 2005 | 12:13 PM
jlathan's Avatar
I had the same issue, dealer stated moisture was getting into the transmission via the fluid fill tube. Problem was corrected, shutter went away, but at 5800 the torque converter and pump failed. Not sure if related but the car has been down 15 days due to unavailable parts.
Old Jul 10, 2005 | 06:11 AM
Zilla's Avatar
Print this out and show your service dept. Free of charge fix:
Reference Number: K72884665
Vehicle Issue: 1700 RPM vibration from exhaust system. Most likely noted at cruise speeds with light throttle application, when MDS (multiple cylinder displacement system) is activating.
Year: 2005
Model: LX - 300, LX - Magnum
Engine: 5.7L HEMI MDS only
System or Component: Group 11 - Exhaust
Symptom: Vibration. Verify that exhaust is mounted and isolated properly, correct as needed. IF all checks lead to no solution it is possible the following will assist:
Repair: A new flex joint has been released to break up the mode. In order to fix the car you will need 2 pipes and 2 spring/nut assemblies (Mopar calls it either a nut or spring, depending on the system. It's the same)
P/N 04581868AH (Muffler, exhaust. Qty - 1)
P/N 04581869AG (Resonator, exhaust. Qty - 1)
P/N 04578363AA (Nut, spring. Qty - 2)
Old Jan 7, 2008 | 09:13 AM
MoparMan's Avatar
Zilla,
Thank you very much for this information! I am headed to my Chrysler dealer this morning to show them your information. This issue has bothered me for three years so I hope this resolves my problem.
Thanks again,
Moparman
Old Jan 7, 2008 | 11:53 AM
moe's Avatar
moe
what engine do you have.?hemi?moe
spigot1
Mar 28, 2014 03:36 PM
wideglide
Nov 15, 2011 10:56 AM
SpudlerT+CTouring
May 19, 2011 05:02 AM
grbullets
Sep 2, 2010 06:44 PM
felix84
Feb 22, 2008 05:34 AM
