Chrysler 300c 2009 front end knock
Old Sep 18, 2021 | 06:59 AM
baff57's Avatar
Default Chrysler 300c 2009 front end knock
Ok i have a front end knock, more usually at low speeds and also on uneven roads, however it only happens when the air temperature is above 25 deg C ish , so i thought rubber bushing getting soft, it sounds central but getting worse as i now also get some vibration, rumble through the pedals and steering wheel.
I have jacked the car and looked at all the ball joints and bushings without finding any play, so i replaced the sway bar bushings, it had no effect. I also had noticed it was obviously a problem to a previous owner as the sway bar links look very recently added.
The thing that concerns me is when i checked the callipers there seems a lot of play in the guide pins, here is a YouTube video , do you think it is excessive? why when slightly hotter?
When i got the car the front right tyre had worn excessively on the outer edge 0-4mm so i had new tyres and had tracking checked, they said it was out but still to few a miles to access if it is now ok.
If i put the car in drive and put on and off the brakes i do get a clunk.
My assumption is with the vibration it has to be wheels / brakes ? Possibly the caliper?
Thanks for your comments
Old Sep 18, 2021 | 12:07 PM
tarhealcracker's Avatar
Check those motor mounts while you are feeling ambitious.
latenitedave
Jan 6, 2021 01:31 PM
kit4410
Apr 29, 2014 01:52 PM
swiederin
Oct 18, 2013 03:10 PM
rydout
Feb 7, 2012 10:17 AM
Erbie78
Mar 16, 2011 11:24 PM
