Cooling Fan
Old Jun 11, 2019 | 07:47 AM
ChryslerHassles's Avatar
Default Cooling Fan
Hello,
2015 Chrysler 300 with the 3.6. Noticed yesterday that my cooling fan is not running in low speed. AC runs fine but fan does not turn on when AC is running. Only the high speed comes on when the temp reaches 230F.
The engine is not overheating. When the high speed comes on, the temp drops to normal.
Any ideas on what this may be?
- Coolant level is Fine.
- Relays looks ok but I have not been able to test.
Since the fan is working and does come on, i am thinking it is not the fan itself being the issue.
Thank you
Old Jun 11, 2019 | 08:49 AM
tarhealcracker's Avatar
Like you, I expect the fan to come on with the AC. If it doesn't then I would suspect a relay issue. Look in you owners manual for relays having to do with cooling fan and/or AC.
I know almost nothing about this problem but I do remember 1 of the first rules regarding trouble shooting - always mechanical and electromechanical suspects first.
Old Jun 14, 2019 | 08:27 AM
So. -------------- What happened. How did it turn out?
Old Jun 18, 2019 | 12:28 PM
Hi tarhealcracker,
Thanks so much for your reply and help. Ended up having to replace the entire cooling Fan Assembly ($773) from the dealer. The resistor on the low end was burned out. Unfortunately, on this vehicle, the resistor itself cannot be replaced as it is integrated with the fan.
I am shocked that the fan would quit as such a low mileage on the car.
Old Jun 18, 2019 | 12:29 PM
Hi tarhealcracker,
Killavolt
Aug 23, 2018 11:25 AM
Silentdub2
Jul 2, 2018 07:57 AM
celamantia
Jul 7, 2014 09:25 AM
dcj
Sep 12, 2013 06:30 AM
apcdrewie420
Cirrus & Breeze
Sep 29, 2010 10:28 PM
