2008 Aspen P0521 code suggestions?
Old Apr 10, 2019 | 06:52 AM
Sessholvlaru's Avatar
Default 2008 Aspen P0521 code suggestions?
This code has recently come up on my Aspen and I’ve tried a few fixes with negative results.
I changed the the oil pressure sensor with a new OEM unit and cleared the code. Light came back on the same day.
I had an oil change about a month earlier and thought that maybe they used the wrong oil. Had a fresh oil change done with 5W-20. Light came back on the next day.
What else can I try? It’s been a couple of weeks since I first got the code, and if I had no oil pressure I’m sure it would have blown up by now.
Could it be the pump somehow?
I really don't don’t want to take it to the dealer seeing as it’s a ten year old truck with 140k on the clock, but I love it and want it fixed right.
Many help would be appreciated!
Old Apr 13, 2019 | 12:35 AM
themps's Avatar
Not an expert, just a shade tree mechanic. But yes from what I can tell it could be the oil pump or the pcm. Or electrical with the wiring to the sensor to the pcm. If it's every been run dry or severely abused it could be worn rings etc. I assume you are not seeing any contamination in the oil? But it's not old enough or has the miles for regular use and normal care to have that happen imo. Were you low on oil when you changed after a month? If so how much?
Old May 1, 2019 | 11:18 PM
Demise516's Avatar
Default 2008 aspen oil pressure sensor are defective
U have to make sure u get the updated verison from the dealer. Local stores still have the first gen. sensors that wouldnt last long
voyager200
12
Apr 11, 2016 04:36 AM
jentsiepak
Apr 1, 2014 03:03 PM
trillosautodetailing
Jul 15, 2013 08:54 AM
valleybill55@aol.com
Apr 2, 2008 06:36 PM
