ABS, Brake, ESP/BAS, Traction Control Dash Light stay on...
Old Sep 25, 2021 | 01:30 PM
  #31
what are the codes
Old Nov 8, 2021 | 01:21 PM
  #32
icemanch's Avatar
I just had this problem. Here is what I did to fix it.
I was getting code C2200 and all of the lights on the dash were on.
I replaced the ABS module with a unit from the Junkyard (You can do this without removing the ABS pump or opening the brake lines).
When you replace the module you have to have the dealer initialize it. However, save some money and buy a Bluetooth OBD connector that works with AlfaOBD. You can use AlfaOBD to initialize the ABS module yourself. Read the instructions as there's four steps to it but, they are all fairly easy.
After that everything was fixed and working. I do wonder if I could have re-initialized the original ABS module and had it work. The new module gave me the same C2200 code at first.
Old May 6, 2022 | 11:41 AM
  #33
Lembi33071's Avatar
What Bluetooth OBD connector did you purchase and where?
I still have the issue and this connector might fix my issue, thanks!
Old Jun 22, 2022 | 08:11 PM
  #34
radiant63's Avatar
I have a similar issue. 2007 Hemi 4WD with 26K miles (i know - it's a garage queen owned by a disabled vet) But I am getting intermittent ABS, Traction, BAS lights. the other day I had the RF brake stuck and got very hot. I have an inexpensive Innova 5110 ODB2 scanner with ABS. Codes are C100A & C1014 - RF wheel speed sensor circuit.
Removed front wheels, calipers and discs and swapped sensors - but got same codes and calipers not stuck so far. So now trying to diagnose what is causing the error - RF caliper, ABS module?
To be continued.
billbon8
Aug 5, 2022 12:25 PM
02 Limited Conv
Feb 4, 2013 09:38 AM
dandy
Oct 29, 2012 08:36 PM
bikerbrad
Oct 7, 2011 06:21 AM
Gasman
Jan 15, 2011 09:07 AM
