Overheating
Old Oct 5, 2007 | 05:11 PM
ricksaldana's Avatar
Default Overheating
I live in Southern California and I am having a problem with my 2007 Chrysler Aspen overheating on very hot days while I am just idling. My temperature guage begins to creep up to 3/4 and my air conditioner begins to blow warm air. As soon as begin to drive the guage will go back to normal, but when I am idling it will begin to creep up again. It's worse on extremely hot days. I have taken the vehilce to the dealership and they replaced the radiator but it has not solved the problem. Does anyone have any answers?
Old Sep 10, 2022 | 07:56 PM
P h I l I p's Avatar
Default Same exact problem now much worse!!!
I have an 2007 Chrysler 4.3 my issue started just like discribed no different what so ever.. now it runs hot to the point I must cut it off and abandon it!! It dosnt seem to leak any fluids. Water pump and thermostat look good! Thermostat is new!! At this point I am just not sure does ANYBODY HAVE ANY IDEA ON WHAT TO DO?? WHAT TO CHECK??
Old Sep 11, 2022 | 07:52 PM
calamity coyote's Avatar
Only things I can think of for overheating:
1. Fan - Is the fan moving as it should be? This is what helps keep air flowing through radiator when at a stop.
2. Water pump - Is water pump circulating water as necessary? Does it have an air bubble in line causing stop of flow?
3. Thermostat - Is the thermostat stuck causing no flow of water? May need to be replaced.
4. Air flow - Are the fins on the radiator or AC condenser blocked? If they are blocked, no air will flow even with fan on.
kakoem
May 10, 2020 04:54 PM
Brian87gt
May 18, 2014 12:09 PM
LHSTAG
Nov 22, 2013 05:29 AM
MeghanL
Nov 27, 2010 09:33 PM
moving on
Jul 19, 2010 10:33 PM
