04 AWD Pacifica has Clunk from the front
Old Jun 27, 2014 | 08:59 PM
  #31
Ripdizzle's Avatar
Default Possible zip tie explination
Originally Posted by ntwrkguy1
Jay,
I'm getting ready to have my mechanic change out the factory sway bar bushings and replace them with the Energy Suspension ones that you used. I need some clarification, though -- I don't quite understand what you meant when you said you used industrial zip ties. What are the zip ties holding in place?
Is there any chance you could post a picture of your completed repair? And after 2 years, how are the new sway bar bushings holding up?
Thanks,
David
David, I think he meant that you wrap the zip ties around the swaybar and subframe, otherwise you may need 2 people to make sure it stays still. I can tell you from experience, you really don't want to cross thread a bolt at this angle.https://www.chryslerforum.com/forum/...es/redface.gif
That's my best guess at what he meant, assuming he may not see this back from two years.
Also, I've posted a link below for those curious in these, as I am:
Amazon.com: Energy Suspension 9.5169R 1-1/16" Sway Bar Bushing Set: Automotive Amazon.com: Energy Suspension 9.5169R 1-1/16" Sway Bar Bushing Set: Automotive
Also, if possible please post before/after shots as I'm very interested in this upgrade.
Thanks,
Mike
Old Jun 27, 2014 | 11:43 PM
  #32
ntwrkguy1's Avatar
Thanks,
Mike
Mike,
That makes sense now, and I'll be sure to pass this on to the mechanic. If you live near an AutoZone, they can get the Energy Suspension bushings for you for $23.99. Mine took two days to get here, so not too bad.
The mechanic I use works at his home garage, complete with lift, so I'll be sure to take some pictures for you guys. I'm hoping this will silence the noise coming out of the front end -- time will tell!
Thanks,
David
Old Jul 8, 2014 | 12:40 PM
  #33
ntwrkguy1's Avatar
Ok....just got back from vacation and picked up my Pacifica this morning.
The "clunk" is gone!
Here's what I had done:
Replaced both front struts with Monroe Quick-Struts
Replaced both inner and outer tie-rod ends
Replaced sway bar bushings with Energy Suspension
Replaced timing belt, water pump, thermostat, serpentine belt and all related tensioners and pulleys
Unfortunately, the mechanic forgot to take before pics of the sway bar bushings. I can post some pics of them as they look now. He did have to modify the bracket slightly in order to accomodate the factory hardware, but he said it was a quick fix.
My first impression was how quiet the car was, and how much better it handled and drove. The struts were the original ones, and they were pretty well shot. The bump stops had nearly disintegrated, and that likely was contributing to some of the noise.
Now if I could only do something about my mediocre gas mileage!!
Old Aug 22, 2015 | 06:52 PM
  #34
jimmy154's Avatar
Anyone know the width of the OEM bushing?
I have a "special" plastic sheet that is designed to have metal slide smoothly on one side and has adhesive on the other side.
I hope to cut it to the right width and slide inside the old bushings after loosening the bolts that hold them.
rtp
May 25, 2024 07:40 PM
Kevin Matney
Sep 20, 2013 03:41 PM
BenjaminA
Jan 10, 2012 04:14 PM
moparrh
Aug 16, 2011 08:51 PM
greenstein8
Oct 4, 2009 09:16 PM
