'04 Pac AC drain problem
Old Aug 14, 2017 | 09:16 PM
Barbara 2's Avatar
Default '04 Pac AC drain problem
Has someone seen the back of the under dash heat/ac box where it has the drain going thru the firewall ? What does it look like ? Ours got the carpet wet only on that side. Sunroof sealing and drains had been cleaned months ago. Before I pull the carpet up to see, curious as to how the water gets out from that drain. Maybe ours needs some sort of resealing. Anyone done that ? Thanks. *BW*
Old Aug 17, 2017 | 10:46 AM
Look under the hood on the firewall for a short section of hose that comes out of the firewall, turns downward and stops. If you can reach it, massage it with your hand to open up the end. Chances are a bunch of debris (small leaves, dirt, dead bugs) that fell into the cowl area below the windshield will drop out. That's your problem. It's quite common.
To dry the carpet, put a small fan on the floor and let it blow over the rug. It'll dry faster that way although it will eventually dry with normal heater-A/C operation. Faster is better to minimize rust and odors.
Old Aug 18, 2017 | 08:45 PM
Barbara 2's Avatar
Thanks for the info.
Do you know how far something can be stuck inside the drain hose to see if it is blocked at the other end ? Maybe a short purge of air might help too. Thanks again. *BW*
Old Aug 18, 2017 | 10:52 PM
The hose is flattened at the end. "Massaging" it should open up the end and allow the gunk inside to fall out, especially if it's dry. Hitting it with compressed air might push the gunk back in there to cause problems later. It could also blow the hose apart or off its connection if it's really plugged. You could probably slip a vacuum cleaner hose loosely over the drain hose to help clean it out if it's stubborn.
There are little cameras nowadays that can look inside a hose like that if you're that curious.
markyb7
29
Jan 22, 2023 06:52 PM
carl
Sep 23, 2015 12:25 PM
smturnbow
Mar 12, 2014 11:21 AM
aschabel
Aug 28, 2010 12:18 PM
Hawwk11
Jun 20, 2010 04:35 PM
