07 chrysler pacifica no air is coming out the front vents
Old Jun 25, 2020 | 12:10 AM
Melissa Rose's Avatar
Default 07 chrysler pacifica no air is coming out the front vents
I replaced resistor nov 2019 and now I replaced the motor blower and no air comes out the front vents and I replaced the blend door actuator what can it be ?
Old Jun 25, 2020 | 07:35 AM
REBEL59's Avatar
With all the parts changing you've done, I would ASSUME that you started off checking fuses and for power at those components. Next item would be the ventilation control panel on the dash. BUT CHECK FOR power to operate interior fan FIRST.
Old Jun 25, 2020 | 10:02 AM
The blend door does not control where the air comes out. It controls the temperature of the air. The mode door controls where the air comes out.
Make sure the dash vents are open. May seem obvious, but don't overlook the obvious.
Old Jun 25, 2020 | 04:51 PM
Default 07 chrysler pacifica no air coming out the front vents
All the fuses look good.. my sister in law bought the motor blower online dont know if that matters
Old Jun 26, 2020 | 08:08 AM
REBEL59's Avatar
Fuses "look good"? DO NOT ASSUME! TEST for power with a 12 volt test probe or with a volt meter to affected circuits and components. Changing parts will do NO GOOD if power or grounds are not there going thru the wiring to them.
Old Jun 26, 2020 | 02:17 PM
Well put the old blower motor back on and now have air comong thru the front vents the new blower motor the wires were backwards so we put the old one in
Aujypaujy13
Jun 24, 2020 10:25 AM
dmartora
Jan 15, 2018 04:41 AM
Stevenfowler1987
Jan 10, 2017 07:52 AM
cruea1
Aug 3, 2010 08:33 PM
Buckjohnsk
Mar 12, 2008 03:11 PM
