07 Pacifica 4.0 in limp mode P076A
Old Mar 30, 2018 | 07:09 PM
LT1/TA's Avatar
Default 07 Pacifica 4.0 in limp mode P076A
07 Pacifica in limp mode
I just bought an 07 Pacifica with the 4.0/62te. The seller said it had transmission problems and that he had changed out a couple of sensors,but it did not fix the problem.I bought it and a buddy of mine towed it to my shop,I drove it and scanned it.It was in limp mode with code P076a,direct clutch circuit.I checked the electrical/wiring and they checked good. I pulled the side covers,then I pulled the solenoid pack/valve body and the underdrive assembly.I inspected the low clutch drum and it looked great,checked the solenoid pack and it seemed the be good.So I put an old solenoid pack from my 08 caravan on the valve body and put the underdrive assembly and the solenoid pack/valve body back in the trans and the Pacifica is shifting great now.I even reused the valve body gasket and transmission fluid.Well the trans fluid looked new anyway.
Old Apr 4, 2018 | 10:29 AM
Frige's Avatar
Cool. I had a new yorker that had the same problem.
8nracing
Sep 12, 2018 04:24 AM
tn_voldad13
Apr 22, 2018 08:59 AM
V84u2nv
Oct 21, 2017 04:13 PM
sawwas72
May 10, 2017 12:20 AM
luellajean
Aug 8, 2007 07:29 PM
