2004 Chrysler Pacifica not passing 2k rpms!
Old Sep 3, 2019 | 12:01 AM
Ramsey Betancourt's Avatar
Default 2004 Chrysler Pacifica not passing 2k rpms!
Ok guys I have a situation,
I recently replace alternator and yesterday I replaced timing belt,water pump, tensioner and pulley (kit)
I installed everything I put everything as it should be
I'm pretty sure I timed car correctly because before I put everything on I started car I it idles perfect! No misfire or anything! So I put everything back on and now I start the car and it idles perfect ... once I try to drive it and rpms try to go over 2k rpms car jumps and tugs and won't go past ....
Am I missing something? Check engine did come on and it's giving me
Crankshaft sensor or camshaft sensor
I highly doubt it's the sensors tho because they had never givin me a issue, maybe I'm missing a ground?
It seems like it's going into limp mode? And ideas?
All sensors are plugged in , would off timing still be able to idle perfect?
Old Sep 3, 2019 | 08:19 PM
what are the code numbers just because the word car or crank is in the code does not mean its sensor related
Kenneth Holm
Jan 26, 2016 05:33 PM
Johnbush1
Nov 29, 2015 09:29 PM
markush
Jan 18, 2012 08:01 PM
kole
Feb 27, 2011 12:05 AM
iroc4life
Feb 12, 2008 05:51 PM
