2006 Chrysler Pacifica Flickering Lights, ABS comes on and chimes, Radio cutting out
Old May 11, 2013 | 12:24 PM
karen1097's Avatar
Default 2006 Chrysler Pacifica Flickering Lights, ABS comes on and chimes, Radio cutting out
I have a 2006 Chrysler Pacifica Touring with 70,000+ miles. When I drive it, the panel lights and headlights flicker, the abs light comes on and chimes, then the radio cuts in and out. I took it to Chrysler repair shop and they first replaced alternator. The problem continued so then they replaced the battery. They had it for a week and the mechanic said he was sure it was battery. I drive it a day after having it back from the shop and am having the same problem. What could the problem be?
Old Apr 5, 2016 | 10:38 PM
johnnyproperty's Avatar
Did you get this fixed? Did you try the 'Ranzy' fix that is posted? My 2004 Pacifica puts on a delightful light show of headlights and interior lights that we are trying to stop.
Old Nov 4, 2016 | 11:21 AM
MNMike's Avatar
Sounds like the same issue as this post:
https://www.chryslerforum.com/forum/...lem-yuk-20589/
Old Nov 27, 2019 | 11:58 PM
clarkaaron.777@gmail.com's Avatar
Under the battery tray is a couple ground posts, they have a few wires on each one. Clean them up and that should help. They are exposed to the weather and corrosion build's up after a while. You will need to remove the battery and tray to get to them.
mreichert
9
Nov 19, 2021 04:37 AM
SMDougherty
Sep 19, 2017 01:41 AM
ranzy
Jul 12, 2015 11:15 AM
smturnbow
Mar 12, 2014 11:21 AM
AmberM
Mar 1, 2013 03:40 PM
